Re: 3pt. Conversion
Posted by Steve Mason on May 19, 2003 at 08:26:10 from (207.177.31.118):
In Reply to: 3pt. Conversion posted by DANWV on May 18, 2003 at 23:27:39:
been researching a 3 point for my C for a while now. I priced both Saginaw and Worksaver. Worksaver was only slightly cheaper than Saginaw and Worksaver uses the touch-control so it is limited in lifting capacity and requires those dang rods to run past your feet.
Since Saginaw has its own hydraulics it looks to be the only way to go for an aftermarket 3 point hitch.
However for me, both are out of my budget so I am building my own 3 point hitch for my C.
Post A Followup
: Re: Re: 3pt. Conversion
