Re: Farmall C problems
Posted by Bill Smith on May 19, 2003 at 12:26:03 from (63.147.130.2):
In Reply to: Farmall C problems posted by Jim on May 19, 2003 at 11:39:56:
There should be an idle adjustment screw on the carb. I would start there. If that fails, I would make sure the linkage from carb to governor is hooked up properly, and the butterfly inside the carb is not loose. I would check all that out before monkeying with the governor.
Post A Followup
: Re: Re: Farmall C problems
