Re: Do any of you guys cut grass with your H and if you do can you...
Posted by ScottyNY on May 19, 2003 at 17:21:09 from (162.40.180.197):
In Reply to: Do any of you guys cut grass with your H and if you do can you... posted by KURT (mi) on May 19, 2003 at 16:24:46:
A couple of thoughts. Is that reel mower ground drive or hydraulic? Not sure how that would work if the latter. I love the idea of a reel mower m'self, but that H is awful heavy on the kind of ground that it takes to grow a lawn that deserves the fine cut of a reel. I wouldn't take it out but on the dryest ground. Okay three thoughts. The most common problem I've heard of cuttin' grass with an H is gettin' it under the trees. The stack don't fit. If you've got a treeless expanse on firm ground and a ground drive mower, I'd say go for it! More than one occasion I've wished I had the ground and the setup for a rig like that, m'self.
Post A Followup
: Re: Re: Do any of you guys cut grass with your H and if you do can you...
