Re: Farmall C problems
Posted by BillWV on May 19, 2003 at 20:02:13 from (129.71.136.164):
In Reply to: Farmall C problems posted by Jim on May 19, 2003 at 11:39:56:
I don't know if a C is like an A or not, but...I was having the same problem on my A. Idling way too fast, the idle adjustment screw wasn't even touching the stop so it was no help. Governor adjustments (I suspected the surge bumper) didn't help. It turned out that somebody had switched the two springs that are on the governor end of the throttle control rod. On mine, there is one long spring and one short. I removed the two springs, swapped places, and adjusted it up fine.
Bill
Post A Followup
: Re: Re: Farmall C problems
