Re: Timing my BN
Posted by J MIRGON on May 20, 2003 at 05:41:28 from (170.224.224.102):
In Reply to: Timing my BN posted by Rodger Wells on May 19, 2003 at 16:00:03:
When I timed my a I used the same procedure you did and it worked good for me. There is a mark in the flywheel that points directly downward, when number 1 piston is at top dead center on the compression stroke, if you use this mark you can be sure that number one is tdc on compression, both intake and exhaust valves should also be closed all the way. I put a mark on the front pulley and the front cover when it was at tdc , this makes it easier to put a timing light on it once you get it running. You may also ground a spark plug to the block and crank the engine just to be sure you are getting spark.When i lined the rotor up with number one plug wire on the distributor cap, I took an old dist cap and drilled out the hole for the number one plug wire this eliminates some guessing, this may you can see for sure that the rotor is dead on the number one plug wire. The firing order should be 1,3,4,2. and the rotor rotates clockwise
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
