Re: 140 hi-crop
Posted by Hugh MacKay on May 20, 2003 at 08:12:15 from (209.226.247.103):
In Reply to: 140 hi-crop posted by Bryan on May 19, 2003 at 19:48:09:
Bryan: I know I could set my regular 140 on 8" blocks and I could adjust my cultivators to go 3" below ground level. I am not sure how well they would work. The Hi-crop is no longer in wheelbase and with larger wheels you actually have less area between front and rear wheels. I am not sure that the cultivators are the same however. The other item one must consider is some ground working tools may be different. The only model number I have ever seen on these cultivators is C-133
Post A Followup
: Re: Re: 140 hi-crop
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
