Re: Re: Re: TA on 460 Gas
Posted by Big Rede on May 20, 2003 at 15:40:03 from (205.188.209.140):
In Reply to: Re: Re: TA on 460 Gas posted by Fritz Tx on May 18, 2003 at 20:26:14:
Take your time and you will get along fine, I ordered a tape on how to overhaul T.A. and after watching that it was simple. 99% of the time low side slippege is caused by the roller pins that lock up when you shift to low, thay get a flat side on them and slip. Replace them and springs that hould them in place no matter how thay look. ck. high side clutch while you are in their, throw out bareing on this clutch runs all the time it is in high side. If you have any leaks on main bearing or main clutch problems good time to fix them. good luck
Post A Followup
: Re: Re: Re: Re: TA on 460 Gas
