Re: 6 to 12 volts with magneto and 10si alt
Posted by ibpidlin on May 20, 2003 at 19:45:38 from (64.12.97.13):
In Reply to: 6 to 12 volts with magneto and 10si alt posted by KEV on May 20, 2003 at 19:30:52:
I am not up to date on what you're doing but if you are using a one wire alt. a lot of times they can use a little extra ground also you need to rev it up pretty good before it will start charging.if using a different style alt. dont forget no juice in no juice out good luck
Post A Followup
: Re: Re: 6 to 12 volts with magneto and 10si alt
