Re: 6 to 12 volts with magneto and 10si alt
Posted by Bob M on May 21, 2003 at 06:39:37 from (165.170.128.66):
In Reply to: 6 to 12 volts with magneto and 10si alt posted by KEV on May 20, 2003 at 19:30:52:
Kev - Presuming your wiring is correct and the alternator is good, the likely problem is the alternator is spinning too slow. A couple tests you can try: 1 - With the motor running at WOT, momentarily jumper the BAT and #1 terminals at the alternator. If the alternator begins charging and continues to charge after the jumper is removed, the alternator is spinning too slow. Need to install a smaller pulley on the alternator. 2 - Find the test opening in the rear of the alternator (approx 3/8" dia hole with a small metal tab visible inside). Again with the motor running at WOT, take a small screwdriver and touch the tip to the metal tab. Then with the screwdriver still touching the tab, ground the screwdriver shank against the side of the hole. If it charges when the tab is grounded, it means the internal regulator is bad. If it does not charge, there's a problem somewhere else in the alternator. Note: If the alternator is working correctly you should read between about 13.8 and 14.5 volts at the battery (actual voltages depends on the temperature and the state of the battery).
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
