Re: Question for Bob M. or any other Guru's
Posted by Bob M on May 22, 2003 at 05:24:35 from (165.170.128.66):
In Reply to: Question for Bob M. or any other Guru's posted by Dennis Gentert on May 21, 2003 at 19:27:55:
Dennis - Check your email - just sent you a diagram for your setup….
Regarding the "no crank" condition you need to determine whether the problem's the wiring, the solenoid or the starter itself.
Connect one end of a jumper cable to the battery + post. Tap the other end to the power terminal on the starter (expect a spark when you make the connection!) If the starter engages when the connection is made, the problem is in your wiring or solenoid. If it does not, the starter itself is bad - probably a brush/commutator problem as one of the other posters suggests.
Hope this helps!
Post A Followup
: Re: Re: Question for Bob M. or any other Guru's
