Switched on B?
Posted by Rauville on May 22, 2003 at 08:25:06 from (209.180.79.141):
Just purchased a cheap old IHC B with mower, and see that at sometime in the past someone added a second push / pull switch wired into the generator as a cut off. Is there any reason that you would need this if the voltage regulator is working? Thanks from SD
Post A Followup
: Re: Switched on B?
