Re: Ratio between Engine and in-Line PTO shaft.
Posted by CNKS on May 22, 2003 at 18:15:51 from (207.178.96.214):
In Reply to: Ratio between Engine and in-Line PTO shaft. posted by Brian on May 22, 2003 at 17:35:48:
On a C or H, max idle speed is 1815 rpm, loaded governed speed is 1650 rpm. PTO speed is 540, but this probably occurs a couple hundred rpm below full throttle. So unless you have a way to load the engine, I don't think you can set engine speed off the pto.
Post A Followup
: Re: Re: Ratio between Engine and in-Line PTO shaft.
