Re: Ratio between Engine and in-Line PTO shaft.
Posted by Sid on May 23, 2003 at 03:44:11 from (202.27.176.157):
In Reply to: Ratio between Engine and in-Line PTO shaft. posted by Brian on May 22, 2003 at 17:35:48:
My Owners Manual (1951) has the following specifications for engine and PTO speeds. Low idle 500 to 550; Max. no load 1540; Max. full load 1400. PTO speeds - Low idle 203; Max. no load 595; Max. full load 541. Hope this sorts it out for you. Sid.
Post A Followup
: Re: Re: Ratio between Engine and in-Line PTO shaft.
