Re: 140 hi-crop
Posted by Big Don on May 23, 2003 at 12:43:59 from (24.101.197.208):
In Reply to: 140 hi-crop posted by Bryan on May 19, 2003 at 19:48:09:
The cultivator mounting frames are different between the standard and high clear tractors.
I think the parallel arms are longer on the high clear to give more travel and the square shafts that go into the mounting hole on the tractor are offset down to help make up the height difference.They were called an A144 cult and later just a 144.
Don
Post A Followup
: Re: Re: 140 hi-crop
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
