Re: Re: Re: Re: Re: Re: Ratio between Engine and i
Posted by CNKS on May 23, 2003 at 20:04:46 from (207.178.96.214):
In Reply to: Re: Re: Re: Re: Re: Ratio between Engine and in-Li posted by Brian on May 23, 2003 at 06:44:44:
All you need to do to set the low idle is to adjust the idle stop screw stop screw so that it doesn't stall, and the idle mixture so that it runs smooth. The exact low idle rpm is not that important. Max idle speed is.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Ratio between Engine and i
