Timing gears on a H
Posted by Bob B. on May 24, 2003 at 19:49:37 from (67.192.52.188):
Need a little help. I am in the reassembley stage on rebuilding my 1948 "H" engine. How do you set the timing mark when the magneto gear/housing is installed? I aligned the two dots, crank and cam dots, when I installed the camshaft, but am a little confused on how to get the mag. aligned. There are two dots on the cam gear directly across from the dot to align the crank and cam.
Thanks in advance. There is a dot on the mag. gear also.
Post A Followup
: Re: Timing gears on a H
