Re: TD18A - wont run on diesel
Posted by Redfan on May 26, 2003 at 01:46:25 from (139.134.63.153):
In Reply to: TD18A - wont run on diesel posted by Kevin on May 25, 2003 at 17:04:57:
Kevin if it sat for a while theres every chance one of the valves in the injector pump is stuck. Happened on a WD6 we had. Just pulled the pump down and cleaned everything and it was right. Regards, Redfan.
Post A Followup
: Re: Re: TD18A - wont run on diesel
