Re: Smokin' H
Posted by 49 Cubber! on May 26, 2003 at 05:55:11 from (206.74.216.32):
In Reply to: Smokin' H posted by John e.c.MI on May 26, 2003 at 05:10:46:
How long was it sitting?Worn rings can and do cause smoking,add some oil past those rings and your compression will be high if theres enough getting by.how did you check compression,with it running or just turning it over?
Post A Followup
: Re: Re: Smokin' H
