Farmall H upper bolster pivot shaft question
Posted by John on May 26, 2003 at 15:51:40 from (192.233.162.165):
I put new oil seals (I used 2) in to stop the oil from leaking down my upper bolster pivot shaft. My bushings, upper bolster pivot shaft, bearings, felt washer are all good. When I assembled the upper bolster pivot shaft into the upper bolster, I first cleaned out all of the old grease in the lower bushing and cleaned out the upper bushing. I wasn't sure so I put some grease on the outside of the thrust bearing and on both sides of that bevelled washer and on both parts of the upper bolster pivot shaft that go into the bushings, did I screw up by putting grease on the outside of the thrust bearing and beveled washer ?
Post A Followup
: Re: Farmall H upper bolster pivot shaft question
