Re: SC carb problems
Posted by FC on May 27, 2003 at 07:12:03 from (66.84.205.26):
In Reply to: SC carb problems posted by red reaper on May 26, 2003 at 20:20:10:
I would check/recheck all passages in carb. I had a similar problem on my C and thought I had checked everything possible. Finally disassembled carb again ran fine wire through small passages and blew out all with compressed air along with a spray of carb cleaner and when I put it back on it ran fine with no choke. All it takes is a very fine piece of debris to cause similar symptoms you describe. Good luck..
Post A Followup
: Re: Re: SC carb problems
