Re: Changing clutch in an H and/or SH
Posted by Fred KS on May 27, 2003 at 07:57:21 from (198.26.125.13):
In Reply to: Changing clutch in an H and/or SH posted by jal-SD on May 27, 2003 at 06:58:44:
Not a whole lot of experience here, but on my 49 H the clutch can be removed from the bottom of the tractor. If the tractor has a hydraulic Lift-All pump, it will have to be removed first. Once the pump has been removed, you can remove the clutch from the bottom of the tractor.
The Lift All Pump, while simple to remove, is heavy and will flip over easily when lowering it. I suggest reading some of the posts on that procedure.
I have not removed the clutch, so apart from letting you know the clutch can be removed from the bottom, I can't talk you through the procedure.
Good luck,
Fred KS
Post A Followup
: Re: Re: Changing clutch in an H and/or SH
