Re: 1066 With A Knock
Posted by RPM on May 27, 2003 at 10:25:57 from (209.152.115.185):
In Reply to: 1066 With A Knock posted by Mitchissippi on May 27, 2003 at 06:04:18:
If running a load on ipto at the time it probably damaged a tooth or bearing from the shock, it would have no reason to harm hyd pump. The live drive from the clutch into the transmission is where I would start, and you will have to split it to find out.
Post A Followup
: Re: Re: 1066 With A Knock
