Re: FARMALL 300 BOGGING DOWN HELP!!
Posted by DAN on May 27, 2003 at 12:40:33 from (63.171.24.10):
In Reply to: FARMALL 300 BOGGING DOWN HELP!! posted by MIKE on April 05, 2003 at 16:22:27:
Mike: If the brakes are not stuck and you have good fuel flow, have you check your compression yet? it should have at least 110 psi per cyclinder. also farmall's have a thick flat washer in the governor that very often have wear stop's or two divits worn into it that wont let the governor arm move when put under load. another thing to check is make sure your governor spring is not to tight. to check the spring and the washer in the governor, just remove the side cover and with a srew driver push the washer fowards and look for the wear spots also the spring should be hanging kind of lose in there. Check your governor by starting the engine, put it at 3/4 throttle, press both brakes down and the engine should bog down for a second and then pick right back up if not then you where to start looking. good luck dan.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
