Re: Amp light
Posted by Ben in KY on May 27, 2003 at 13:13:39 from (192.76.82.90):
In Reply to: Amp light posted by Mark H on May 27, 2003 at 13:03:58:
Mark, It could be the alternator or a wiring problem or a loose fan belt. I would check to be sure the belt is tight first. If that is ok I would use a voltmeter to be sure the Alternator is charging when the engine is running. Measure the tractor voltage with the engine off. Should be about 12.6 to 13 volts or so. measure it again with the engine running at something over 1,000 RPM. You should now read about 13.8 - 15 volts max. It is possible that the alternator is charging but the circuit driving the light is bad.
Post A Followup
: Re: Re: Amp light
