Re: B has a miss fire
Posted by SAm in NS on May 28, 2003 at 14:57:18 from (24.138.71.44):
In Reply to: B has a miss fire posted by jps on May 28, 2003 at 13:38:24:
The firing order is cast onto the block. Just beneath the spark plugs. I would pull the valve rocker cover and give them a liberal dose of oil and make sure all the valves are free. If one of the valves is stuck down because of being sat so long then it will leave you with no compression in that cylinder and a miss. Hope this helps. SAm in NS
Post A Followup
: Re: Re: B has a miss fire
