Re: SMTA hydraulics
Posted by Aces on May 28, 2003 at 18:16:17 from (205.187.81.192):
In Reply to: SMTA hydraulics posted by Mark R. on May 28, 2003 at 17:23:45:
SMTA will not have up and down unless you have an other valve on it. It could have valve under the right front of the gas tank. Should be one out let on right side of the resivor and two on left side. 1/2" NPT fittings just like your H they work the same way.
Post A Followup
: Re: Re: SMTA hydraulics
