Re: Re: 300 IH, COIL CONDENSER BLUES
Posted by jal-SD on May 29, 2003 at 11:17:05 from (12.17.66.79):
In Reply to: Re: 300 IH, COIL CONDENSER BLUES posted by jmyt_47 on May 29, 2003 at 11:06:55:
My 6V H distributor kept going through points, etc. until I had the bushings & shaft rebuilt @ my C-IH dealer, after it fried the 2nd coil. (I'm a slow learner.) It was spendy, but less expensive than a new distributor & no more aggervation. Could your problem be that the bushings are wore out? (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: 300 IH, COIL CONDENSER BLUES
