Re: HYDROLIC HOOK UP
Posted by Adam r on May 30, 2003 at 10:14:19 from (205.213.111.51):
In Reply to: HYDROLIC HOOK UP posted by bubsdad on May 30, 2003 at 09:51:28:
Take off the filler cap and screw a tee to the
fitting and put a plug in the top and hook the
return line on to the other port in the tee. When
you run any kind of two- way hyds you need th
solid plug insted of the origional cap if you
want to run one way again take off the solid
plug and put the old cap back on. The solid
cap keeps the oli in the system when it is
used on two way, the old cap has a breather
and the oli will shoot out fo it when it is left on
and two way is used.
Post A Followup
: Re: Re: HYDROLIC HOOK UP
