Re: pitted cylinder head
Posted by Bill Smith on May 30, 2003 at 10:52:47 from (63.147.130.18):
In Reply to: pitted cylinder head posted by rustyfarmall on May 30, 2003 at 06:09:45:
I believe you have the right idea. New valve seats will fix the mechanical part of it (you might want to have it plained if the gasket surface is un-true). As for the rest of the surface area that is pitted, I would give it a severe wire brushing or perhaps a sand blast job just to insure all the rust and stuff gets off. If you sand blast, don't sand blast valves, valves seats, rocker arm assembly, ext. You will want to sand blast with all that stuff removed. And do appropriate cleaning afterwords to insure it is clean of sand.
Post A Followup
: Re: Re: pitted cylinder head
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
