Re: Bob M----Help!----350 Farmall with no spark
Posted by Bob M on May 30, 2003 at 13:42:58 from (165.170.128.65):
In Reply to: Bob M----Help!----350 Farmall with no spark posted by Neal on May 30, 2003 at 11:49:48:
Neal - Several possibilities here: Distributor is out of time, coil has failed (secondary winding is open), condenser has gone bad. Suggest you proceed like this: 1 - Pull the center wire out of the distributor cap. Stick the wire on a good spark plug, lay the plug on top of the coil then crank the motor. If you get a spark at the plug, problem's gotta be distributor timing - skip down to #4 below. If no spark, the problem's electrical - proceed to step #2 2 - Check the coil. Swap it for a known good coil if you can. Or if you have a VOM or DVM, take a resistance reading on the secondary (between the high voltage terminal and the coil shell). The meter should show somewhere in the neighborhood of 2,000 - 3,000 ohms or so. If you get a resistance reading near 0 or infinity, it means your coil is shot - time for a new one! 3 - If the coil checks out, suspect the condenser. Swap it for a known good one - condensers are cheap and easy to swap. 4 - If you find the coil is sparking, problem's gotta be ignition timing. First make sure the plug wires are properly installed. The wire from the #1 (front) cylinder should go to the terminal on the distributor cap marked "#1". Working CLOCKWISE around the distributor, the remaining wires should go to #3, #4 and #2 cylinders respectively. Next, mark the side of the distributor under the #1 terminal and remove the cap but leave the rotor in place. Turn the engine by hand (or bump it with the starter) until the timing mark on the crankshaft pulley is aligned with the pointer on the timing gear cover. Now look at the distributor rotor - it should be pointing to the mark you made on the side of the distributor, or pointing exactly 180 degrees opposite. If it's not, loosen the clamp holding the distributor base and rotate the distributor until the rotor aligns exactly with the mark (or is pointing exactly 180 deg away from the mark.) Then tighten it back down. The motor should be timed good enough to get it to start. Hope this helps!!
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
