Re: Bob M.
Posted by Bob M on May 30, 2003 at 16:09:33 from (66.66.123.133):
In Reply to: Bob M. posted by Joe in Ks on May 30, 2003 at 14:52:48:
Joe - First check the obvious: Wiring is correct and the drive belt is tight. Then with the motor running about 1/2 throttle temporarily jumper between the BAT and #1 terminals on the alternator. If the light goes out and the ammeter now shows charge, the warning lamp is not drawing enough current. Swap the bulb for one that draws at least 200 ma - an automotive side marker bulb (#168, #192, etc) is good - and your problem should be solved.
If jumpering the BAT/#1 terminal DOESN'T work there's a problem with the alternator, despite what the parts places are telling you...
Good luck!!
PS - If the alternator is charging you should read somewhere between 13.8 and 14.6 volts at the battery...it will vary somewhat with temperature.
Post A Followup
: Re: Re: Bob M.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
