Re: 300U carb
Posted by Dennis on May 31, 2003 at 03:35:48 from (64.12.97.13):
In Reply to: 300U carb posted by D.Sellers on May 30, 2003 at 09:51:35:
I had a similar problem, but it slowly got worse. I rebuilt the carb with new needle and seat several times and finally figured out I had a hole in the float. I epoxied it and now it runs great. Just take the float out and see how heavy it is and see if gas leaks out of it. Just an idea.
Post A Followup
: Re: Re: 300U carb
