Re: Farmall 140 resistor
Posted by Hugh MacKay on May 31, 2003 at 13:45:56 from (209.226.106.91):
In Reply to: Farmall 140 resistor posted by Will Fleenor on May 31, 2003 at 12:16:48:
Wil: How long have you had this tractor? Does it have a 12 volt alternator? What is the coil, 6 or 12 volt? If you are running 12 volts and have a 12 volt coil, no resistor is even needed. On most conversions I have done I've used 12 coil. If you ask why, I've watched to many people fool with those damn resistors. I had two of them, the first and last were one in the same.
Post A Followup
: Re: Re: Farmall 140 resistor
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
