Re: 1586 Torque Amplifier
Posted by Aces on May 31, 2003 at 18:43:13 from (205.187.80.61):
In Reply to: 1586 Torque Amplifier posted by Mario on May 30, 2003 at 19:58:19:
Lever forward is direct back is in TA warm up the tractor before you use the TA and when you shift down on a hard pull make sure the speed is right shift back up when your are sure the engine can come back to rpm don't shaft down to stop a big load. When you shaft the TA do it fast. Heep it adjusted to the letter.
Post A Followup
: Re: Re: 1586 Torque Amplifier
