need an engine guru (HELP)
Posted by wh on June 01, 2003 at 06:31:48 from (152.163.253.102):
just had an farmall h overhauled at local dealer (top quality dealer). new sleeves,pistons,the works. they sent the head to local shop to be redone. local shop has top quality reputation. had work there in past and allways pleased. now to problem - engine started to smoke severly after about 10 hours of use. local dealer came out , drove it and determined it was oil coming around valves. took it back and took valve cover off. found that there were no seals around valve stems. orded seals and installed them. worked fine for about 10 hours. started to smoke again. extreme amount of smoke - especially after going down an incline. took plugs out and could wipe the oil off them with finger. dealer is going to pick it up soon and go back into it. he is stumpped as to problem. once back into it, it may be obvious. anybody have any ideas? wade
Post A Followup
: Re: need an engine guru (HELP)
