Re: IH 340 U power steering fluid
Posted by Catskill Pete on June 01, 2003 at 10:58:59 from (205.232.37.102):
In Reply to: IH 340 U power steering fluid posted by Fred Mills on May 31, 2003 at 19:30:34:
Depends on if and how badly the steering box leaks. If no leaks then Hy-tran is fine. Small slow leaks 90wt, extreme leaks synthetic grease.
Two things to keep in mind, the steering box is a seperate component from the actual power steering. The 340 uses a power assist system. The mechanical components of the system are the same as non power steering. IH then added a 'hydraulic booster",[the best way I can think to describe it] to the system. The "booster" runs off the tractor hyd. system. The steering box remains a self contained resevior to lube the mechanical steering component. I have never seen one yet that did'nt leak to some extent, just a matter of how badly. You do not want the steering box to run dry [very expensive] so keep it filled with whatever works.
Post A Followup
: Re: Re: IH 340 U power steering fluid
