Re: Farmall Cub Lo-Boy Won't Start
Posted by Randy Mc on June 01, 2003 at 12:04:23 from (209.173.164.65):
In Reply to: Farmall Cub Lo-Boy Won't Start posted by David Washington on June 01, 2003 at 11:31:11:
I had the same thing happen to me once and it was the on/ of switch. Check to make sure it is working and that switch also has a good ground. Good luck!
Post A Followup
: Re: Re: Farmall Cub Lo-Boy Won't Start
