Re: Farmall 300 Utility, Left Front Wheel Cuts In
Posted by Hugh MacKay on June 01, 2003 at 17:02:38 from (209.226.247.117):
In Reply to: Farmall 300 Utility, Left Front Wheel Cuts In posted by John L on June 01, 2003 at 14:58:41:
John: Sounds as though your caster may be off. When you look the tractor over from different angles do the front end caseings for spindles have the same angle to vertical. The clamps that clamp axle adjustment, the center pin hole may be worn and these may be clamped tight at different angles. If it were toe in I would think it would act same both ways on steering. Ocasionally those clamps come loose and if operator is not right on top of it the holes for center pin soon get egg shaped. That utility axle is a bit unique also. I know in rebuilding those hole in a Farmall you want the spindle shafts slightly ahead of vertical at bottom. I would say the one that is cutting into ground is wrong, compare it to the other one and go by that.
Post A Followup
: Re: Re: Farmall 300 Utility, Left Front Wheel Cuts In
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
