Re: Re: Re: Re: Re: C runs Poorly
Posted by Chet on June 01, 2003 at 18:11:07 from (64.12.97.13):
In Reply to: Re: Re: Re: Re: C runs Poorly posted by Carm on June 01, 2003 at 13:48:42:
It sounds like you have covered all the electrial problems. You said that when you pulled out the choke it ran smoother. I would check the fuel line for dirt. If you have an in line filter replace it, pull the sediment bowl and clean it and the screen if it is still there. Also remove the fuel line and inspect it. Blow it out with A LITTLE compressed air. If it is a 'rubber' fuel line replace it and the clamps.
Post A Followup
: Re: Re: Re: Re: Re: Re: C runs Poorly
