Re: idle screw useless
Posted by karl f on March 29, 2009 at 20:03:51 from (172.129.208.129):
In Reply to: idle screw useless posted by karl f on March 29, 2009 at 11:29:55:
took the bowl off again and poked with welding tip cleaners, sprayed with carb clean, blew with a hose. everything seems to let air move. the only thing left would be to remove factory plugs for even more thorough reaming. could it be the wrong screw? I am using a caseih gasket and everything seems to be lining up.
does the carb for the 400 use the throttle shaft and bushing for an economizer circuit like the e12 carbs on earlier models?
I forgot to get the carb number off the tag..
karl f
