Re: Starter problem
Posted by RayA on June 01, 2003 at 20:48:41 from (24.117.114.165):
In Reply to: Starter problem posted by Don on May 29, 2003 at 12:05:42:
You said that the shaft was well lubed and it turned freely but didnt say if the bendix would slide forward on the shaft. I had a bendix stick on the shaft one time and it would not slide forward to engage when starter was spinning. I used a screwdriver to gently pry a bit behind the bendix to unstick it so it would slide and havent had any problems since. Good luck.
Post A Followup
: Re: Re: Starter problem
