Re: Re: F-12 valve lash
Posted by Bob S on June 02, 2003 at 02:49:33 from (66.227.142.201):
In Reply to: Re: F-12 valve lash posted by James Williams on June 01, 2003 at 05:56:43:
The magneto point gap is .013 when the rubbing block is on the high point of the cam. The valve clearance is also .013 with the engine warm.
Post A Followup
: Re: Re: Re: F-12 valve lash
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
