Re: C runs Poorly
Posted by Big Orn on June 02, 2003 at 15:19:14 from (63.169.152.131):
In Reply to: C runs Poorly posted by Carm on June 01, 2003 at 12:47:14:
(1) Check opening at the bottom of your gas tank - I had to remove my tank completely to remove a flat sliver of hard plastic that became trapped over the opening when calling for gas.
(2) Zenith Carb - Make sure the float has not got a small leak in it - making it starve for gas
(3) Make sure all passages in the Zenith is open. Some openings in the carb can become clogged and you can't tell it. This is a MUST. All passages serve a purpose
Post A Followup
: Re: Re: C runs Poorly
