Re: Re: 400 cam gear
Posted by Bob M on June 02, 2003 at 19:01:22 from (66.66.123.133):
In Reply to: Re: 400 cam gear posted by RPM on June 02, 2003 at 15:03:44:
RPM - Apparently even left hand threads don't cure the cam gear loosening problem! The nut on my Super M unscrewed completely and fell off (found it in the bottom of the gear cover when I took it off). The cam gear had "flopped" itself to death over a couple hundred hours of running without the nut to hold it on.
When I opened it up I was a bit surprised to find the camshaft and nut had left-hand threads. Apparently the orginal right hand threaded camshaft had been replaced at some point in the earlier in tractor's life.
Post A Followup
: Re: Re: Re: 400 cam gear
