Re: farmall cub hydrolics
Posted by Phlogiston on June 03, 2003 at 09:38:55 from (65.107.123.212):
In Reply to: farmall cub hydrolics posted by bobby on June 03, 2003 at 09:30:13:
The arms each have a grease zerk fitting under the gas tank. Hit them with grease. Also check to see if the Hy-tran fluid is at the proper level.
Phlogiston
Post A Followup
: Re: Re: farmall cub hydrolics
