Re: 544 oil leak
Posted by RAS on June 03, 2003 at 21:54:24 from (66.87.12.37):
In Reply to: 544 oil leak posted by jon on June 03, 2003 at 18:06:50:
Is it the 239 diesel? If so there are two wedges that go between the pan gasket and the rear seal housing. If they are mising it will leak and you will think it is the rear seal. Remove the pan & gasket and look at the back of the engine. You will see a place where the wedges go.
Post A Followup
: Re: Re: 544 oil leak
