Re: Re: Re: setting timming on Mc cormick hay bale
Posted by Hugh MacKay on June 04, 2003 at 05:26:12 from (209.226.106.76):
In Reply to: Re: Re: setting timming on Mc cormick hay baler posted by fran on June 03, 2003 at 13:13:55:
Fran: On the back of your baler by the knotters, where drive line comes in from front of baler via the packing forks. There should be a bevel driving gear on end of shaft coming from front and a bevel driven gear on the knotter shaft. Those two gears should have timing marks that line up with each other. Just turn the machine by hand until you find the marks and check to see if the teeth with the marks mesh. If they don't it is not a hard job. Just unbolt knotters at bottom and loosen knotter shaft enough to move the driven gear to right position.
Post A Followup
: Re: Re: Re: Re: setting timming on Mc cormick hay bale
