Re: Re: Farmall A and 100 gas tank
Posted by Stan(VA). on June 04, 2003 at 05:34:13 from (208.59.157.2):
In Reply to: Re: Farmall A and 100 gas tank posted by Hugh MacKay on June 04, 2003 at 05:10:11:
Hugh is right on the mounting height differences, but your bigger problem is that the outlets are in a different place. When the SA came out, they moved the outlet/sediment bowl forward to clear the touch control unit. So you can't use an A/B tank on a tractor with touch control.
Stan(VA).
Post A Followup
: Re: Re: Re: Farmall A and 100 gas tank
