Re: Super A + Cub imps.
Posted by Hugh MacKay on June 04, 2003 at 05:41:23 from (209.226.106.76):
In Reply to: Super A + Cub imps. posted by GOATMAN on June 03, 2003 at 09:33:34:
goatman; Usually any piece of equipment that bolts to the cultivator lift frame will mount. I have never seen any item that wouldn't fit, especially going from Cub to SA. Going the other way may be a problem due to size. The lift frames will not interchange. My dad traded a Cub off for a 130 in 1958, kept his cultivators but not the lift frames. I have a gut feeling that every implement that IH ever built that bolts only to the cultivator lift frames, is completely interchangable as long as you have the proper lift frame for tractor. Where you will get in trouble is an implement that bolts to frame of tractor as well.
Post A Followup
: Re: Re: Super A + Cub imps.
