350 Utility hydraulic troubles...
Posted by Steven@nd on June 04, 2003 at 16:38:17 from (12.15.56.38):
The engine pulls when all the levers are in the nuetral position. If I run the 3-point up and down the engine doesn't pull.
Also, it won't hold an implement up, it gradually drops. And the hydraulic lines get so hot you can't touch them, the old oil on the line actually started smoking.
Any ideas what's wrong? Something isn't allowing oil to bypass in one of the valves - are these valves complicated to take apart and fix?
Thanks for any help!
Post A Followup
: Re: 350 Utility hydraulic troubles...
